Bank 1 or bank 2 doesn't matter. If in fact it is the intake gasket leak you will fix all at the same time anyways. Read this:
DTC P1174
Fuel Trim Cylinder Balance
CIRCUIT/SYSTEM DESCRIPTION
The Fuel Trim Cylinder Balance diagnostic detects a rich or a lean cylinder-to-cylinder air/fuel ratio imbalance. The diagnostic monitors the pre-catalyst heated oxygen sensor (HO2S) signal's frequency and amplitude characteristics by calculating an accumulated voltage over a predetermined sample period. An imbalance is indicated when multiple samples of the accumulated voltage are consistently higher than the desired value.
The common denominator is that you have replaced all related items and the only thing left is the mechanical condition of the engine, the intake gasket leak. Engine is known for this because the oe gasket sealing ridges get distorted from poor design. The Felpro gasket kit is the way to go as well as AC Delco Knock sensors while in there and the harnesses from either AC Delco or Dorman. Look at you tube for the step by step.
By the way, I would not argue with ElGuapo, rocken, this early in the morning. He's not himself when he is cranky. Give him a Snickers.
