Heater control issue
kd_unruh
Colorado Springs
I have a 2001 Tahoe and lately I have had an intermittent problem with the heater control. Every once in a while I will run the heater, then when it's warm in the cabin, I try to lower the temp, but it still stays on high heat. Even turning it to full cold and turning on the A/C has no effect on it. The fan speed and whether I have it blowing on feet, through the dash or defrost makes no difference. Since this is intermittent, I'm assuming it something that's sticking, but I have no idea where to start looking. Can anyone provide some input on this? Thanks!
treepete
Genesee Twp, WI
switches check out OK? sounds like the switch isnt working right once its warm in the cabin.
jpmaniac87
gotta get it from the stealership most likely. it's the hvac blend door actuator
kd_unruh
Colorado Springs
Thanks for the help. It's been performing fine the last couple of weeks. I'm going to try to find that actuator. Thanks again!!!
