Heater blows cold air temp gauge up and down
tlefmur
My wife was driving to work and gave me the call. It seems the temp. gauge is on the move (up and down) and the heater is blowing cold air. My first guess was to check the in/out lines for the heater core then to check the coolant level. After some research, It looks like I should check the thermostat, temp. sensor, and intake gasket as well. I've had to do troubleshooting before, but I am a novice and it usually takes me twice as long to locate everything. Any ideas. We are on a limited budget and that's why I do all the work myself.
73shark
KC, MO area
If the engine is not heating up, then most likely it's a thermostat that's stuck open.
