This pic is from the neg post from the battery....I also have a cable running from the positive post from the battery to the alt, and a cable running from the engine block to the ground on the fire wall. Should I be running the cable from the negative post on the battery to somewhere else instead?
Another thing......
Here's a quote that I found on page 6 of this site
http://www.fullsizechevy.com/forums...o-electronics/120517-nbs-big-3-upgrade-6.html
"I come more from a car audio background than a fullsize Chevy one, and I've only had my 02 'Rado for 2 years. However, I've had plenty of experience when to comes to car audio, and I know that it's VERY important to put an inline fuse on the positive link. The positive factory link you are supplementing is fused for a reason. If you don't fuse the additional positive link you are putting in, you risk burning your entire vehicle to the ground if your electrical system shorts out.
Would you rather replace a $2 fuse if you get a short, or the entire vehicle because you were too lazy to wire in a $10 inline
fuse setup?
Also, in the case that your sound system's capabilities far exceed that of your alternator (entirely possible for any of you who might compete in SPL competitions), a properly sized fuse on that link will protect your alternator from working harder than it should in case of massive over-draw.
Just my $.02, I'm new to the forums and look forward to some interesting discussions!"
Based on what this guy is saying do I need to add an inline fuse from the positive terminal of the battery to the alt? Or, what I have connected is fine?
1. Battery positive to alt
2. Battery negative to chassis (I hope I wired this correctly from my above pic)
3. Engine block to ground on the firewall
Of course I don't want to burn the hoe down, but once again....any help I can get will be greatly appreciated.
