LaredoTexas
- Sep 29, 2007
Hey Laredo......did you get my PM about the led tails?
yea... sorry i dont have signal mirrors...
I dont think your bulbs are bad.. did you change your fuse as i told you? look at that.. HID bulbs should not go bad that fast.. specialy both at the same time..
which fuse should i change?
Have you done the mod yet? If so what has gone wrong? Different fuses for different probs.
it did work for 2 days and after that its not working
with the 15v fuse would 55w h11 hids for the reverse lights be ok?
thanks!
If you are refering to you the HID reverse lights, you will need to check the reverse light fuse, which if I remember is fuse 15 (pull your owner's manual out to confirm). The factory fuse is 10v, I upgraded mine to 15v and havent have problems since (knock on wood).
Hey -- question: You guys keep sayin' "10v" or "15v". Aren't fuse capacities measured in Amps? I'm assuming you meant you will install a 15A fuse, right?
I put HID's for my backup lights. The Ruby Red IPCW LED's and the 6000k HID's look amazing together. 6000k headlights, fogs and backups is a good combination.
I had my dealer swap my fuse with a 15v(a) as well. Thanks to Laredo for his write up.
