Fuel Pressure???
Z71Heat
New Jersey
does anyone know offhand what the correct FUEL PRESSURE ( in LBS) should be on a 00' 5.3 ?? When I go to start the truck in the morning, it starts and stalls on the 1st crank. The 2nd crank it fires up fine. I replaced the fuel filter, plugs,wires and I run 93 octane. I will put some injector cleaner in this week. Any ideas?? I was thinking there was a possibility of a pressure problem???
greengumby
Joysey City Newjoysey
sounds like the fuel pump itself is starting to go ...usually when you turn the key you can hear the pump prime before you turn it over...
I wanna say 50-55psi, spikes to just over 60 with a walbro after the system turns off. You should not loose much pressure even with the truck sitting overnight.
XcesiveSlyd
Boost is correct. I just changed mine in the Parking lot of Wal Mart last month on vacation. I was getting 5PSI from the original. Check it. if you have a manual follow it. If not, above 50 and less than 60 with the key on and engine off is what you should get.
Z71Heat
New Jersey
well, I still hear the "buzz" from the pump itself, so the pump isnt bad. Yesterday I poured 2 bottles of chevron injector cleaner in, filled it with 93 ocatne and off I went. I DONT have the hard start problem in the morning anymore. It seems like it "wants" to not fire up but it does. I cleaned the Throttle body 10,000 miles ago, maybe its due for another cleaning. I will test the pressure next week.
The fuel level sensor is BAD on my pump, when I fill up it says I ahve no gas etc...its and intermittent problem which is annoying but I wont replace the pump until it goes.
