Front end Hum noise
shiznit
I got a 2001 4x4 with a front end hum. I replaced the driver side wheel bearing thinking this was the problem and sure enough it wasnt. I recently drained the transfer case and that wasnt the problem. I start hearing the hum after 20-25 mph and gets louder the faster I go. Anything else I can check?
TIA, Steve
Fordf100
I have that same noise and I'm in the process of working on it I've been hearing a lot about the front and rear tires having two different dimensions from wear, what fluid did you use in the transfer case I've heard to use ATF-fluid
