flowmaster on a 95 sdr
Surfer27
Anyone install a 50 series Flowmaster on a 95 2dr. I am looking at stock number 943053. Is this a direct fit" 3" od offset is the spec.
thanks
98hoe
I don't think so. Just put some flows on my hoe and the pipes exiting the cats were small as hell. Like 1" 1/2 or something. Just crawl under and have a look. With a pipe bender/spreader anything will work.
jwpotts0413
USA
stock pipe is 2", but u can buy a 2" to 2.5" reducer at autozone for like $2. i used a dual in dual out 2.5" flowmaster 40 on my 2 door after i got rid of the glass packs. midas charged $40 to weld it in since i had all the parts. its loud as phuck b/c i got the turn down tips welded right onto the muffler which is under the rear seat. i may get the cats cut off, i might as well u already can't hear the damn radio lol
sasquatch094
ohio
on my 95 4dr hoe, my exhaust is like 3inch all the way back.. i did replace it all but im not sure if i regraded or not tho
skimo
FYI, had Flowmaster on my 97 2dr....LOUD..never really thought about it but the body is shorter and the pipes are right there. Like and Echo chamber...If you like that..i did for awhile but took it off..Good Luck
