First Oil Change: Lessons Learned
neweagle
Okay, I did it; decided to get my hands dirty, roll up my sleeves, and change the oil in our '07 LTZ (5.3L Flex). I changed to synthetic at Jiffy Lube back at 1829 miles. It had been 8268 miles since, and I still had 16% showing on the DIC, which projects out to about 10,000 miles between changes. For this change, I went with Mobil1 Extended Performance 5W30, and the Mobill filter.
I know that it doesn't save much money (if any), but I guess I just wanted the peace of mind of knowing that everything had been done right. So, for the next noob who wants top change their own oil, here's a few things I took away:
1) Finding the jack points was easy. There's are long, thick metal bars that run parallel to the running boards (chassis frame?); I used the front of these as the jack points.
2) Once I was under the engine, the filter and drain plug were easy to spot. The filter is all the way at the bottom of the engine, which makes it easy to reach. I was actually surprised at how small the filter is; it's about half the size of the filter on the 4.0L engine on the Explorer that we traded-in.
3) There are no bars or wires in the "spurt path" of the oil once you remove the plug. It looked like the spurt might reach a part of the chassis, but it didn't when I removed the plug, so as long as you position the catch pan right, there won't be a bunch of chassis that you have to wipe off.
4) The filter was the worst part to me:
a) Although it's easy to reach, it's partly surrounded by the crankcase, so your best bet is to get the strap type of filter wrench. The thin metal of the strap will fit in the small space between the filter and the crankcase; that might not be the case for the endcap-type wrenches out there. Mine didn't fit, but fortunately, the folks at Jiffy Lube had hand-tightened it at the last change, so I was able to get just enough of a grip to loosen it. I filled the new filter with oil before putting in on, to minimize the dry start.
b) The biggest mess that I made was removing the filter. Since the filter screws in vertically, none of the oil that's in it will drain out when you remove the plug. There's a LOT of oil that starts to spill up over the top and down the side out as you unscrew the filter and break the seal between the filter and the crankcase. I wasn't expecting it, so it got a little messy. Next time, I think I'll punch a hole in the bottom of the filter and let it drain before I unscrew it.
Hope this helps someone!
one trick i learned while i was working at a mechnic shop was to put some oil around the seal of the filter, that way it comes off MUCH easier with alot less strain.
also another question, i guess im a oldie here but i always change my oil at 3000, even though i use synthetic oil, do i need to change it so often?
High4
Just a thought, consider using a jack stand or some ramps in the future. Had a friend killed in college due to the jack slipping and suspension clipping his head. A very expensive oil change.
AZSCTACO
Phoenix, AZ
That is overkill and your wasting your $$$......
I usually change every 5000K (cause it's easy to remember :) ) but some say you can safely let it go to 7-8K. Mercedes and BMW don't call for a oil change until 15K per....as per the Manual. So that tells you something when it comes to intervals with Synthetic.
OStateFlyer
Tulsa
I've got a stupid question...I'm seriously considering synthetic for the first oil change and thereafter (I've got 700 miles on it now), however, I'm not going to do oil changes myself. Will a Chevy dealership do synthetic changes or do I need to find another reputable place to do them?
AZSCTACO
Phoenix, AZ
If you do find a reputable shop to do it.....you will be paying about 3-4 times what it would cost to do it yourself. And you can have the peace of mind it was done right. It is VERY easy......
I've heard many stories of shops leaving filters loose, old gaskets left from the old filter - which leads to oil leaking, to much or to little oil put back in, filter over tightened, oil caps left off.
OStateFlyer
Tulsa
I've changed the oil in previous vehicles, but honestly, I don't enjoy it. I like playing with my cars, but changing the oil has never excited me. Not to mention the used oil that you have to store and eventually get rid of. For slightly more money and about the same investment in time, I can let the dealership worry about it while I go across the street and eat lunch. That's how I justify my laziness anyway. :D
Getwired
DC Suburbs
Yo, OState, I ONLY go to my GMC dealer for my synthetic oil changes. Yep, they cost more than regular (materials are more $$), but it's usually a quick and easy stop. My dealer does Mobil1 for me every 6000 miles while I go across the street and eat and chill out. Seems I'm not the only one who doesn't care to do this himself...
AZSCTACO
Phoenix, AZ
How much are you guys getting it done at the dealers???? DIY and it will be around $30.
William91204
I got this crooked guy at a carwash .. you just leave 20 bucks in the cup holder and he changes ur oil..charges an extra 5 for synthetic .. it's great =)
Getwired
DC Suburbs
Wow we're getting off topic... And I thought I was the clown around here! :D
Thanks neweagle for the tips on DIY oil change! Kudos for doing it yourself; I have wondered how difficult/annoying it might be on these trucks. And thank you most of all for helping me reinforce my decision to take to in to the dealer while I sip my coffee and read my paper! :thumbsup:
Hardin Thicke
1) Finding the jack points was easy...........
2) Once I was under the engine.........
I'd never, ever crawl under a vehicle while it's jacked up, even if the tires are still on it. Instead, lay a couple pieces of 2x10's on the driveway on top of one another, but staggered so they look like steps. Lay them on the driver's side only. Now, drive the Tahoe up the "steps". I use 3 layers which allows enough lift for me to shimmy under it with a small pail to catch that rediculous sideways stream of oil.
Note: Forget using the standard drain pan. The oil comes out initially with such force, that its hard to estimate where the stream is going to land. My first drain was an absolute mess! That's why I use a bucket. It's much easier to catch the initial burst of oil. What were those jabroni engineers thinking when they put the drain plug on the side of the pan!
