I too bought a 99 Tahoe back in December and upon inspecting the truck I noticed the front drive shaft was missing. I figured what the heck... so I pulled the 4x4 fuse and drove it 3 hours back home. (it was a good buy)
So fast forward 3 months and now I am curious as to what needs to be done for repair.
I dropped the 4x4 fuse back in the fuse box, and with the truck in neutral I can press the 4HI button and the light will flash twice, t-case motor tries to engage then returns back to the 2HI position on the switch. when I press the 4LO button it sounds as if the actuator below moves but then resorts back to 2HI, and sometimes 4HI. Auto 4x4 will stay lit upon pressing the button, also sounds as if the t case moved to its position. I now have a Service 4X4 light on the dash. If I crawl under the truck and manually spin the front output shaft of the T case it is still locked in 4x4 in all scenarios , but the 2HI indicator light is on. I clamped my gopro under the truck to video the front output shaft and it is for sure spinning in all switch positions.
I understand I need the front drive shaft to make this fully testable, but why would my t-case be locked in 4x4? I'm not trying to just throw parts at it for repair, but check all the obvious items first. Are there any test procedures to rule out bad components/switches? I have jostled the wiring to rule out crap connections, yet found no corrosion or pin discoloration. It is a 136GM by New Process Gear if that helps paired with a 4L60E trans.
also how can you read the transfer case codes on a 99? there is no pin 13 on the DLC to ground so you can count the lights flashing on the switch indicator lights.
Any help is appreciated!!!
Thanks
Andy.
