Fans stuck on. . .
rockymt21
Realized today that the fans for the A/C - Heat will not turn off. I have the knob set at OFF, and it will stay on whether its A/C or Heat. Anyone ever have this problem? Is it a DIY fix? Or is it going to be a garage deal? Expensive?
Thanks, Dan
yukondoit
Gallup, NM
I think I had the same problem happen to my 02 Kon. It would stay on full blast, even with the Kon off. It eventually killed the battery. What I did was I took the fuse out, took 1 of the battery cables off, put the fuse back in, then put the batt. cable back on and finally start it back up. It worked. Don't know what caused it in the 1st place but it hasn't happen again. All together it took like 5 mins. Hope this helps.
rockymt21
That does help.
Maybe thats why my truck wouldn't start the other day, and its been a little hesitant recently. Do you have any helpful pictures as to what Im doing here?
Thanks, Dan
