The other red wire you need is below the brake master cylinder...taped up to a wiring loom just like the one between the fender and fuse box...the two red wires have different sized ring terminals, so there is no chance of mixing them up on the studs.
Go to the hardware store and get two nylock nuts to secure the ring terminals to the studs...I believe one was 8mm and the other was either 5 or 6 mm?? Sorry, my memory fails me right now...
Gene,
Thanks to your messages, I was ready to install tonight. But I ran into a snag!
First off, I found the four wires under the dash. That took quite awhile, but all looks good there. However, the two red wires under the hood have become an issue. I found them (what I thought was both) right where you said they would be… between the fender and the fuse box. When I unraveled the wire, I found that there was only one… not two!![]()
I looked and looked, but there is only one wire coming out of the bundle, as shown in the picture below. Do you have any suggestions or insight on this?
