EGR VALVE
chevyluver
So. Cal
Hello People!!!
Just want to know if it would be easy to change my EGR valve... or should i take it to a shop?
THANKS!!!
peterey2
i agree. look it over, its very easy.
peterey2
yep. yank the electrical connector, take out the two bolts at the flange of the EGR valve, take off the gasket (replace it), clean the surface and put on your new one. with mine, it made it a lot easier to take the air filter housing off (TBI motor)
sasquatch094
ohio
yeap, and if your check engine light was on befreo, your supposed to take off the battery cables for a while when you do this... what code did u pop? or how do u know its bad
peterey2
true too, theres a trouble tree to test the soleniod. a lot of times its either the solenoid or a sticky valve that just needs to be cleaned out.
sasquatch094
ohio
i think my solenoid is bad, they told me it was the EGR valve it that wasnt it, so i might have to get that... u know a cost on one of those off hand??
chevyluver
So. Cal
Thanks for all the good info... the code p0404 came up when i did a scan....
Thanks Guys!!!!!!
peterey2
has this code just started since its been cold?? i had one a few years back only throw a code in the winter time. problem was that a little moisture got onto the valve, and overnight it froze and didnt allow it to move! if youve cleaned your EGR out, id just go ahead and replace it.
JP422
Torrance
nice... my next 'service' was to do was to clean out my EGR... I just wanted to pick up a new gasket from the dealer before I removed it.
I dont have a code, but wanted to clean out the unit as a preventative maintenance.
Anyone of you clean your EGR's before?
peterey2
yep. can of EGR cleaner. smells just like carb/choke cleaner. let it set. move the valve manually with your hands and throw it back in.
