Dual 1 ohm Fi BTL 15" sub
Limited00
Memphis Tennessee
I just purchased a Dual 1 ohm Fi BTL, and just realized....I don't know how to wire the sub. I have a 4000 watt 1ohm stable amp, but how do I wire the sub to the amp? I'm lost...:confused2::nonod::smilielol: Help please
YukonMud
Washington
With only one sub you can either get 1/2 Ohm, wiring in parallel, or 2 Ohm, wiring in series. With the amp you have I would run it at 2 Ohm which would require one positive (+) and one negative (-) be run together and the other positive & negative be run to the amp. See diagram:
Limited00
Memphis Tennessee
That's kinda what I was thinkin. If i wired down to 1/2 an ohm on a 1ohm stable amp, I'd blow my amp. 2 ohms is ok I guess!
clean95
sacramento
half ohm stable 4000 watts a piece (2) 18 inch elemental design the wiring is crazy! just have to make sure that ur amp can handle it... and 32 herts...
