I just got my 2008 Tahoe back from the dealer for the same issue. It seems the service writer hadn't heard of this either. It's very disconcerting... Especially as it didn't exhibit this behavior for the first 3 to 4 weeks of ownership. Perhaps it doesn't do it until it hits the 1000 mile mark? Not sure what my mileage was when I first noticed it, but it was probably close as I have 1200 now a week or so later.
I asked the service writer how would I know if there's a problem with the charging system if it regularly fluctuates from 12V to 15V? He said it'll probably drop to 10V and the truck won't run anymore. I asked why GM put a gauge in if it's not gonna be of any help? I'll know that I have a problem when I break down!! He had no answer to this. I think I'd have preferred an idiot light instead!
They gave me a copy of GM Document ID# 2042756, but the following is copied from a previous post and says nearly the same thing:
Document ID# 2000522
2007 GMC Truck Yukon XL Denali
Subject: Voltmeter Gage Fluctuation - keywords battery charge camper cluster electrical excessive fluctuation gage gauge generator intermittent ipc lamp light low operation trailer towing tow volt voltage wire #PIT3331D - (07/27/2007)
Models: 2005-2008 Cadillac Escalade, ESV, EXT
2005-2008 Chevrolet Avalanche, Silverado, Silverado Classic, Suburban, Tahoe
2005-2008 GMC Sierra, Sierra Classic, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
with Regulated Voltage Control (RVC)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that their volt gauge is fluctuating between 12 and 14 volts on their full size pickup / utility vehicle. Starting with the 2005 model year, light duty full size pickups and utilities, are equipped with a new Regulated Voltage Control (RVC) system. This system reduces the targeted output voltage to 12.6-13.1 volts when in "Fuel Economy Mode" to improve fuel economy. The alternator may exit "Fuel Economy Mode" if additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems which usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation and NO repairs should be attempted. See picture below for the normal operating range of the voltage gauge. Review PIT4426 if having concerns with keeping a camper/trailer battery properly charged.
Recommendation/Instructions:
No repairs should be attempted and please reference the owners manual under Section 3 (Instrument Panel) "Voltmeter Gage" for more information.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
