Driveline Vibration at 35mph
bluetahoe
Looking for some input here.... I have 99 Hoe 4x4 with manual transfer case. When I get to 35 mph the truck starts to vibrate when I'm on the gas. When I let off it stops vibrating. Just for s**** and giggles I put it in 4 HI last night on the way to work and it stoped the vibration. Me and my buddy are thinking U-joints,, but I'd rather not got through the trouble of changing them if its not it.
BTW it has 113K on it and I just bought it a month ago from a dealer, so I don't know much history on it.
Thanks
Matt
SNAPPY
U-joints are not very difficult to change at all. That does not seem to be your issue though. If it was a driveline thing I would think it would do it in 2WD and 4WD. I do not know much about Tahoes as I'm a new owner myself but I would check the front and and mabe wheel balance? I know I had an issue like this on my 99 Jeep Wrangler and it was the front hub on the left side. Just a thought.....
bluetahoe
Not sure if it makes a differance but I don't feel it in the steering wheel at all. Just kinda makes the whole truck shake. That's why I was thinking ujoints. I am mechanically inclined just never experienced this issue before.
41racing
If the ujoints are factory, you can usually tell if they are, and grease is coming out of the seals I'd replace them. I haven't seen a factory joint yet that when the grease starts go seep out that is good.
fyremanpat
Is it possible that one or more of the tires threw a weight? But under load it doesnt allow a vibration...Jus throwin it out there
mygreen98
pull off both driveshaft and visually inspect the needle bearings each cup on each ujoint. i had same issue, all looked dry, then went on to find one was so dry it had no grease in it and rusted completly.
