Door Panel removal help 01 Yukon
NCgatorguy
Charlotte,NC
Anyone got any idea about how to do this? I did get the door handel off but am a little afraid to "Pry" it anymore than I have? Any help would be appreciated!
The mirror access panel in the upper front corner unclips. The trim around the manual lock lever pops off. The trim around the interior door handle unsnaps; start from the back. The switch panel with the pwr window and lock switches is clipped in place. Just pull up on this and unplug the harnesses. You'll have a 7mm screw behind the switch panel that needs to be removed, as well as one underneath the front corner of the door pull/armrest. After you remove all the trim and the screws are removed, pull upwards on the panel. Once it is detached from the door, you'll have to reach behind the panel and unclip the tweeter harness and pull straight out on the light socket on the lower corner of the door. That's it.
