So... I replaced my door bushings on my driver's side. It wasn't good....
First off, here's how the door bushings go in.
We rested the door on a floor jack
From the top, I used a 12" long 3/8" drive ratchet extension and drove the hinge pin downwards.
From the bottom, I used the hammer and pounded the hinge pin upwards.
We pulled the door away slightly. Door fell of the jack and scratched up the paint on the quarter pannel real bad.
I did everything I could to get the bushings out... I used a screw driver, hammer, etc, nothing worked. Finally, I used the 3/8" drive extention to drive out the old bushings.
I used a circular file to slightly open up the bushing entrances and then tapped them in with the hammer. The bushing's flat top goes between the hinge halfs. This is the part that actually wears away.
I put the pins back in and used the other end of the 3/8" drive extension (the open end) to drive the clips onto the pins.
Everything lined up after that and the door closes easily. I wish I had pictures, but I was more pissed off than anything about the paint getting f*cked up.
Hardwarz
Hardwarz
