Disabling Rear AC
WrenchGuy
I want to remove the rear AC.(hardly use it, made a boo boo, and could use the room anyway...lol)
Is this possible while retaining the front AC?
Is it as easy as plugging off the rear supply lines?
Will the Recharging of the AC change? (psi)
Thanks!
Sepiroth
Spam Executioner
Kouts Indiana
Is this possible while retaining the front AC? Yes provided you block off the rear A/C lines correctly.
Is it as easy as plugging off the rear supply lines? In the past it used to be.
Will the Recharging of the AC change? (psi) No provided one goes with the A/C fill rate as a vehicle w/o rear A/C.
WrenchGuy
Cool.
I could find out what I need at the parts store then.
Thanks.
