YukonRidin23
- Oct 15, 2008
alright, if you guys saw my last post i went and picked up a 97 yukon 2 dr. i was told the transfer case and the rear differential neede repair or replacement. after looking at it, i think the transfer case is fine, but the rear differential is missing a couple bolts and has been through by someone else obviously. so im wondering if you guys think the ring and pinion would need to be replaced or what other parts are known to wear in there? the truck still shifts extremely smooth, changes from 2wd to 4 hi-lo perfectly, goes in reverse smoothly, and forward smoothly but will make a grinding noise sometimes? i think that the previous owner ran it in 4 hi going down the highway and thats what would cause the problem, correct me if im wrong?
