Dead mis in 2nd cylinder
mossyoakman827
TN
Ok i have a 1997 tahoe which i purchased from ebay cheap knowing it had a miss so i did the normal checks first new plugs, wires, dis. cap, rotor button. still nothing so i took off my intake noticed a leak into cylinders not just the number 2 due to a gasket break i went ahead while it was apart put brand new 350 vortec heads on and set them reinstalled everything still a mis so i went ahead and replaced all my fuel injectors and still a mis check engine light is on and so i pluged the code reader only to find out what i already know all it says is number 2 cylinder mis could this be in my electric system any ideas would be very much appreashted thanks:yesnod:
brodg
do you have compression in cylinder2? also check the big square plug on top of the intake it is for the injectors look close for a widened terminal or any broken wires
mossyoakman827
TN
hey yes to the compression test ill check out the plug first thing tomorrow thanks alot
mossyoakman827
TN
ok so everything looked ok if i hooked up a test light could i probe thoese wires while truck is running and the light from the tester come on if working?
