Cylinder 3 Misfire
rkrepcio
I have a 96 Tahoe LS with a 350. Put a new motor in it recently. New plugs and wires, new distributor cap, and motor. we replaced the fuel injector assly. checked valve lash. #3 spark plug. checked all plugs. replaced the module and coil with a known good test unit. Did fuel pressure test. read 30 pounds. replaced filter, pump, module, and sending unit. Still misfiring Cylinder 3 only.
