Cruise control not working... brake lights the cause?
Hardwarz
Ohio
I've been having problems with my cruise control. It won't activate 95% of the time. I read on other threads that some problems with the cruise control are caused by the brake light (people replacing the bulbs with LED bulbs, lights burned out, etc.)
I tested my brakes and when you touch the brake pedal, the brake lights come on. When you press a bit harder, the brake lights go out. When you floor the brakes, the brake lights come back on.
I'm going to guess that this is a bad brake switch?
Hummm... now that I think about it, the brake switch is connected to my remote start. I might have to disconnect remote start to test this. Does that sound right?
Anyone else have this problem?
Hardwarz
lexr1racer
Lexington,Ky
I just replaced the fuze on mine but if your brake lights are working ,it may be the switch ??? Good Luck !
