crazy brake problems HELP
cracker bear
so i got an 05 z71 tahoe at slow speeds when i turn the wheels the car applys the brakes . the harder i turn the harder it presses the brakes up to the point i can spin the rear tires!! i think that the spool valve is bad in the hydro boost unit and the higher PS pressure is over assisting the brakes.. wanted to know if any one else has had the same issue and what fixed it
