Sepiroth
Spam Executioner
It's a good thing the posts weren't really dealing any longer with intakes then.
The posts shifted to talk of head and head gasket failures.
I have a 2002 1500 Silverado the V8 5.3 with 75k. It is leaking coolant into the oil. At this time they are pulling the heads to see if they are cracked. They told me I may have to replace the Engine. I think the sucks only 75k out of an engine how will Chevy stay in business building trucks like this.
Subject:Information on Gradual Coolant Loss Over Time with No Evidence of Leak Found #06-06-01-019B - (06/12/2007)
Models:2004-2006 Buick Rainier
2001-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Blazer, Silverado, Suburban, Tahoe, TrailBlazer Models
2001-2006 GMC Envoy, Jimmy, Sierra, Yukon Models
2001-2004 Oldsmobile Bravada
2005-2006 Saab 9-7X
with 4.8L or 5.3L VORTEC® GEN III, GEN IV V8 Engine (VINs V, T, M, B, Z -- RPOs LR4, LM7, LH6, L33, L59)
This bulletin is being revised to include engine RPO L59. Please discard Corporate Bulletin Number 06-06-01-019A (Section 06 - Engine/Propulsion System).
Some vehicles may experience a gradual coolant loss over time. A very low percentage of cylinder head(s):rolleyes2: manufactured with an embossed Castech logo may develop a porosity crack in a very specific area.
Inspect the cylinder head assembly to determine if the casting was manufactured by Castech. This can be accomplished by inspecting for their casting logo located on top of the intake port, under the rocker arm support rail and in the spring deck cavity portion of the cylinder head.
Important: If the cylinder head(s) are Not a Castech casting, follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
If the cylinder head(s) is a Castech casting (1), inspect the area around the five oil drain holes for witness marks indicating coolant seepage over time (2).
Important: If No evidence of coolant loss is found on inspection of Castech casting cylinder head(s), follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
The crack location can be found in any of the five cylinder head(s) oil drains. This can be seen as a clean or shiny area, on an otherwise stained surface (1). Pressurizing the cooling system at this time may reveal coolant, air, or a combination, weeping in the described area. If inspection reveals evidence of coolant witness marks (1), replace the entire cylinder head(s) assembly.
© Copyright General Motors Corporation. All Rights Reserved.
Document ID# 1986750
I see, possibly a massive recall or class action lawsuit in GM’s future!
P.S. not trying to call anyone out, but these vehicles have "dry" intakes, not "wet" intakes like back in the good oil "R" motor days, so, leaking intake gaskets would NOT cause any coolant in the oil or any coolant loss at all, but rather a lean condition and usually sets off the SES light when cold startup
Has anyone experienced coolant loss without external leaks? We have a 2001 Tahoe with a Vortec 5300 engine. We have 85,000 miles.
