Coolant leak
elmora805
Oxnard,CA.
Whats up guys I have a question i have a 2000 tahoe limited that leaks coolant when the reservoir is full. The reservoir can be empty and it wont leak. You would thing that the leak is coming from the reservoir but the puddles are under the radiator. Any help will be appreciated thanks.
GMCYukalade
NC
Follow the hose coming out of the resivor - to the radiator, see if it has any cracks or splits in it
elmora805
Oxnard,CA.
Ive checked that hose and all is good. the reservoir is on the passanger side but the puddle is on driver side. I've replaced the radiator and cap. And still the leak. Ive noticed that the hose that goes from the radiator to thermostat never has any pressure. Anyways Im still searching thanks for all the help.
96cherry
livonia
coolant
make sure you double check the water pump, it can be decieving
GMCYukalade
NC
Yes, double check the water pump - and also check the intake manifold make sure it isn't leaking
elmora805
Oxnard,CA.
Can my cooling system be clogged somewhere. It never overheats, stays at normal temp.
95ThAHOE
CT
I had a similar coolant leak, itd always leak if i filled it up but i could leave it with barely enough to circulate and shed be fine. Anyways it turned out to be leaking out of the heater control valve i believe, dont know if you have the same problem but its worth checking.
96cherry
livonia
how the hell do i get my profile picture on here it keeps saying upload failed
elmora805
Oxnard,CA.
Thanks for all the help guys, shes still leaking I just have to make some time to take things apart to check them out. Will post when Ive figured it out.
