I noticed yesterday that the heater went cold and sure enough, there was no coolant in the expansion tank. I topped it off and then noticed the temp going up then down and when I checked it again, it needed filled again. All in all, I ended up adding 2 gallons. When I used to check it regularly, it never used any coolant but then my wife has been driving it and I have been negligent in checking it.
During the process of adding these 2 gallons, I checked for leaks...none. Also, it seems to be be running okay, although maybe a little rough which leads me to suspect head gasket. Other than that, what could cause coolant to disappear???
I've got 238K on her without any major engine work.
