Completly Shaved Copper & Black Yukon
tybardy
very nice... darker tails would be better... maybe if you get time one day you could take a close up of the backup camera...
Copper&BlackYukon
Thanks
Here's come close ups of the back up camera. It used to have a plastic sleeve from the key lock (which I oringally machined the ID slightly larger to acomodate the old camera) I replaced the old camera and welded a aluminum sleeve in the hole to close the diameter down. The camera is s Pyle IR, the white dots are the IR bulbs.
note: everyone's hatch is aluminum, not steel like the rest of the truck. It's done this way b/c a steel hatch would be too heavy. Just in case someone is thinking of taking their mig welder to it. I wouldn't think this would apply to those of you that have the split doors on the back.
And yes I know how bad the "fancy tea cup pinky" looks in the last one...
Copper&BlackYukon
Forgive my ignorance but how do you get into the vehicle with no handles?
Completely understandable man, I get asked that on a daily basis. If you scroll up you will see a close up pictures of the inside of the door. There is a cylinder holding on to a section of stainless steel wire. That cylinder is actually an electro-magnet with 75lbs of pulling force. When a button is pressed on my key remote, a receiver box pulses power to the electro-magnet (actuator) and pulls the latch as if you would have, had you pulled the handle. A spring loaded push at the bottom of the door pops the door out about 6 inches.
krunchy
Chilliwack BC Canada
does that just work for the drivers side or can you pop all doors? for instance if you have others with you how do they get in
Copper&BlackYukon
Every door has it's own, as well as one on the rear hatch, and one on the rear glass. Every door also has it's own button to push and pop that door. I also installed 6 buttons on the ceter console that will allow me to pop any door, hatch & glass.
withac
Eastern Idaho
Completely understandable man, I get asked that on a daily basis. If you scroll up you will see a close up pictures of the inside of the door. There is a cylinder holding on to a section of stainless steel wire. That cylinder is actually an electro-magnet with 75lbs of pulling force. When a button is pressed on my key remote, a receiver box pulses power to the electro-magnet (actuator) and pulls the latch as if you would have had you pulled the handle. A spring loaded push at the bottom of the door pops the door out about 6 inches.
Sweet man, that is a sic set up.
MadMedwyn
That's probably the most hardcore Yukon I've seen. Awesome job, do you take that to shows?
Copper&BlackYukon
Thanks Guys
I plan on taking it to a few shows once the interior is complete. Down here in Miami people don't mess around when it comes down to hooking up their rides. I wanted to blow even them away. Once the trailer is done I'm hoping to get into a Mag or two...maybe I'm just dreaming...
Copper&BlackYukon
If anyone wants my old carbon fiber tails, you can have them for free, just pay the shipping. I was going to toss them, but if someone wants here wants them, they're yours. They have a couple flaws but look pretty damn good, for being free.
Update on the truck, I stopped by line-x to drop off the steps from the running boards, and apparently they can color match line-X now!! Some guy got his 105th Harley anni Ford done in the same copper I painted my truck, and it looked bad ass. So I told him to do the steps in copper line-x. With the gloss black step surrounds it should look pretty sweet. I'll post pics once they are on.
tybardy
Update on the truck, I stopped by line-x to drop off the steps from the running boards, and apparently they can color match line-X now!! Some guy got his 105th Harley anni Ford done in the same copper I painted my truck, and it looked bas ass. So I told him to do the steps in copper line-x. With the gloss black step surrounds it should look pretty sweet. I'll post pics once they are on.
Ill take em... cal me 480 343 1603 and we can work out the shipping
Or if you want just hit me up in my profile and we can figure it out that way... i will send you a money order or check or whatever... I think i can even use paypall, right?
Copper&BlackYukon
Line X Steps are back and installed
Finally, Finally my running boards are done, and my copper color matched line-x coated steps are installed. I must say it looks hot! It came out better then I expected, props to Line-X of Lauderdale here in south florida, they def know what they are doing.
tast101
Colton, CA
Damn that looks good.
yukondoit
Gallup, NM
nice dude. Hey, I was looking at your Kon, and I thought how would your rims look if you were to powercoat the lip copper? Since you have the black and copper look going. :confused:
Copper&BlackYukon
Just a couple more shots that I think really give you an idea of what the copper steps do for the look of the truck. I think it really sets it off, and it only cost $100. Good idea for those of you who are looking for a quick and easy style mod, considering the step pulls right off.
