code P0440
camjamb
A while back my 2002 Tahoe's check engine light came on and showed code P0440. My only sympton has been the gas tank not venting. I can hear the pressure releasing when I loosen the gas cap. Doing a search I think I have it narrowed down to either a purge valve, or a fuel tank pressure sensor. Anyone had this problem before and how hard is it to fix?
Thanks
camjamb
Changed the purge valve and it seems to be fixed if anyone has the same problem
