I wonder what happened to the 6 speed transmission.
From what I've heard, it is still a 2009 option.
Not much changes. For the 08 'burb you can order the 6 speed even on half ton.
Jim
Just went with an 07 Yukon XL Denali with the 6 speed. Just learned herewith that there is a difference between 4WD and AWD. Ever thought this is the same thing.
I hate to say this but the new GMC Sierra Denali is growing in me
Me too! I want one in black.
All Wheel Drive basically has a differential between the front and back where part time or 4x4 is locked front and back and side to side in the front (on some trucks). If you were to use part time four wheel drive on surface streets it would bind the gears and possibly damage your drive line. If the road is slippery (really wet, snow, sand) then the tires would slip and the gears would not bind, but if they all have solid traction then that is where the differential is needed to allow some slipping in the drive line. Hence AWD...
I wonder why the hp numer is a bit les where torque is the same.
Also please don't go for the 2008 hybrids. I am more than sure that some flaws have to be corrected for the 09 models. Having said that I still wonder why the 07 rigs have been flawless. GM must have done a great job here. That's why I bought a secong 07.
Jim
You're welcome. If you check the hundreds of reviews out there I can hardly find any one which is totally negative complaining about the truck falling apart or such.
The only issue on the complaints is fuel economy. I wonder if there is such a large spread or if it is just driving habits. With my Chrysler Town & Country Diesel I know someone getting 17 MPG whereas I get 39. For the 'burb I get 18 to 19 mixed. My fingers are crossed to see what mpg I get with the Denali.
Regarding hp I think that over 300 hp is just fine with my Suburban and should be even so with the Tahoes. My F-250 Diesel has more than 450 but that's a truck, though.
Do they have the same gear ratio?
