Car sub replacement
zzwb2
Johnson City, TN
I have been reading through lots of threads trying to find out the most cost efficient way to replace my stock 8" sub located in the back of my 01' Chevy Tahoe.
From what I have gathered, (and please correct me if I am wrong) I would be safe by replacing the stock sub with an 8" Rockford and splicing a Line Out Converter after the factory amp?
Also, I have begun to try and pull the interior cargo panels out but cannot figure out how to remove the cargo net button. (the quarter size black thing a few inches up and to the left of the sub enclosure) How do I remove it?
Any help or suggestions would be of great help. Thanks in advance!
Zach
kcciticard
The cargo net button just unscrews. Just use a set pliers if it is to hard by hand.
zzwb2
Johnson City, TN
I got the cargo net buttons off with some pliers, I assumed they were simply screwed in but didn't want to pull or twist to hard and break it off if that wasn't the case. Thanks for the help!
Anyone have insight on how to hook up/wire a Scosche output converter to my new 8" sub? I may even consider buying a new small amp and mounting it in the empty space behind the paneling or in place of the jack if anyone has ideas or recommendations.
zzwb2
Johnson City, TN
I may do something like that in the future but for right now I'm focused on using the stock amp for two reasons: because I am not real comfortable running a power supply all the way to the battery of my car being an amature and never have done anything like this, and because I have a stock head unit with little way to control a big amp or sub.
I'm mostly looking for help connecting a scoche output converter to a Rockford Fosgate 8" I picked up off crutchfield.com
Thanks guys
oneradride
Omaha
I’m running the factory head unit with a line output converter and I love it, keeps the little as* holes from steeling your stuff.
If you are using the factory amp why do you need the converter? The signal to the factory sub is what is going to power the Fosgate right? What are you going to use the converter for?
zzwb2
Johnson City, TN
I have no idea what I was thinking, your right I didn't need the output converter to wire the new sub in. I hooked it up today and there is a noticeable difference between stock and the Rockford, I'm pleased with the results. What kind of amp are you using? I think I may want to try and get a little more out of this miniature sub woofer. ;)
oneradride
Omaha
Lol, you are about where I started, fortunately I have had some experience doing this kind of thing. Save that LOC you will need it to add an additional amp. Get a mono amp just to run the sub(s) the output of the amp will depend on the kind of speakers you are going to run. The mids and highs in theses trucks are fairly good and you shouldn’t need to mess with them too much unless you are going to go full tilt.
When you are ready send me a P.M. or bump this post and I’ll walk you through it.
oneradride
Omaha
Give me everything you know about the Fosgate sub you installed please - size – ohm – max wattage – RMS, ETC. The speaker signal is back there and you can tap your LOC in by the sub in the back. Either way you are going to need to get some extra 12 volt power back there to power an additional amp.
Don’t be intimidated by running a power line. These trucks just snap apart and there is plenty of room to make it all stealth. The key elements of running a designated amp line are;
FUSE it! I attached mine at the factory junction block by the number one cylinder, just behind the alternator. There is a big stud there (underneath the black pop-off cover) waiting for an additional wire. Run the entire line PRIOR to attaching it to the stud.
On the fire wall (as you are looking at it head on, just to the right and a little below the brake booster is a black circle that is stamped into he sound deadening material. This piece will pop out and behind that you will find a small dimple in the metal of the firewall. Drill a 1 inch hole there and insert a grommet. You can get a 1 inch grommet at any parts store in the help section for under 3 dollars. This protects the power line from chaffing and rubbing through. DO NOT skip the grommet!
(***NOTE: if you do not have any aftermarket stuff on your truck there should be plenty of room to drill this hole BUT always check BOTH sides PRIOR to drilling)
Between the junction box where you are going to make the initial connection and the firewall needs to be fused!
Continue running the line, the carpet lifts right up and the sill plates pop right off. Run it down the driver’s door sill opening under the pillar trim (you shouldn’t even need to remove it) then past the rear door sill (this one pops right off also). Tip the back seats down and finish your run. Since you have already installed an aftermarket speaker in the factory location I’m assuming you already know how to get the back panel off.
After you have the wire all the way back to the rear of the truck it’s time to make some connections. Back under the hood, remove the fuse and make your connection to the junction block. Not until the amp is completely connected will you return the inline fuse to the holder. Take some seam sealer or silicone and fill any remaining area inside the grommet, around the power line to seal back up the cabin area. You can add some split-loom to make everything under the hood look completely factory and tie-wrap any line out of the way, that may to too close to moving parts.
I think Boost ran his this way, but I’m not sure what he used for a trigger lead. You’ll need one of those or your amp will be on all the time. I connected my LOC behind the head unit and tapped into the power antenna lead for a trigger then ran everything back all together.
