neworleans
- Sep 15, 2012
Hello,
I am looking at a 2001 Tahoe Z71 4x4 with 145K miles that has a reconstructed title. The owner is my friend and he told me that the damage was on side, 2 doors were replaced and frame was repaired as well. He is asking $4000.
The problems are:
The rear differential leaks little bit.
Front tires are worn unevenly
He says that sometimes car gives "reduced engine power" message and car starts loosing power and you have to pull it over, wait little bit and then you can drive it again. Car doesn't overheat when it gives this problem. Has anybody had this type of problem? I a thinking it might be a sensor but also could be anything. What could it be??
Before buying this vehicle, I wanted to get your advices and ideas.
Thanks in advance...
The problems are:
