thanks guys, today im cleaning off the rims inside, and all the wheel wells and underneath as well. each hub has an adapter, that im going to paint red, along with each caliper, and then a new rubberized undercoat. i think the inside of the rims are damaged a little(corrosion spots), so i was thinking of maybe getting that painted as well, but not sure if ill like it yet. anyways, the reason i took the rims off is because i needed an easier access to the rear differential, which to my father and i looks fine, and seems as if we just replace the bolts and fill it that'll work.
Im pretty sure a gear went in the transfer case though, it shifts smooth, and will ride forward and back with no clunk, but while moving, sometimes it sounds as if a "gear" slips, and grinds really loud until i put it in park and back into gear? if this is the case and the front and rear are still solid, ill order up a new transfer case right away. as for the rancho rsx remote compression adjuster for the rancho rs-series shocks, he told me it needed the compressor replaced, when i got under the truck the ground wire was unplugged, as soon as i fixed that it worked great.
As for the seats, there made by a company called steelflyer. they make marine and rv seats, as well as custom home pieces. im guessing these are just rv seats? i cant find any model identification number or anything, but i do need to order a part for the rear right one so i dont really know where to go from there..
