build sticker codes
Surfer27
anyone have a reference or a web site that will help decode the build codes on the sticker inside the glove box?
kinda curious what these all mean
thnx,S27
lowlife
Document ID# 1700643
2007 Chevrolet Chevy Suburban - 4WD
RPO Code List (Escalade ESV/ Suburban/GMC Yukon XL)
RPO Table RPO
Description
The production/process codes provide the description of the Regular Production Options (RPOs). The RPO list is printed on the Service Parts Identification Label.
AE7
Seat Front Split, Driver, Passenger
AG1
Adjuster Front Seat Power, Multi-Directional, Driver
AG2
Adjuster Passenger Seat Power, Multi-Directional
AJ1
Windows Deep Tint, All Except W/S and DRS
AK5
Restraint System - Seat, Inflatable, Driver and Passenger
AL0
Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector
AL4
Seat RR - Bucket
AL6
Restraint - Cargo
AMF
Lock Control - Additional, Programmable, Remote Entry, Multiple Units
AM8
Seat RR - Bench, Split Stowable
ANJ
Window Tinted - Export Compliant, Non-Deep
AN3
Seat Front, Individual, Non-Bucket
AP3
Lock Control, Entry - Remote, Keyless Entry, Start
AP8
Lock Control, Entry - Remote Entry, Extended Range
ARL
Plant Code - Arlington, TX, USA
ARS
Adjuster RR - Rear Seat, Power, Stowable
ASF
Restraint - Roof Side, LH and RH, Inflatable
AS3
Seat RR - Suburban/Utility
AU0
Lock Control, Remote Entry
AU3
Lock Control Side Door, Electronic
AU5
Lock Control, Entry - Remote Entry, Low Power
AU8
Lock Control, Entry - Remote Entry, Specific Frequency
AW2
Seat RR - 2 Passenger
AX4
Restraint Conversion - Seat, Manual, European
A04
Windshield Tinted, Less Upper Shadeband
A31
Window Power Operated, All Doors
A95
Seat Front Bucket, High Back, Driver and Passenger Recliner
BAG
Parts Package Export
BD2
Ornamentation Exterior - Delete
BPH
Appearance Package Chevrolet - Off Road
BRS
Steps, Runningboard, Side, Retractable, Power
BS1
Insulation Acoustical Package
BVE
BVU
Steps, Runningboard, Side, Molded, Black
BVV
Steps, Runningboard, Side, Tubular, Black
B30
Floor Covering, Carpet
B33
Covering Rear Floor Mats, Auxiliary
B37
Covering Floor Mat, Front and Rear, Auxiliary
B39
Covering Floor Carpet, Load Floor
B58
Covering Floor Mat, Front and Rear, Carpeted Insert
B71
Molding, Wheel Opening, Colored
B85
Molding, Body/Side, Exterior, Bright
CD5
Wiper System Windshield, High Speed Antilift
CE1
Wiper System Windshield, Pulse, Moisture Sensitive
CE3
Wiper System Headlamp
CF5
Roof Sun, Glass, Sliding, Electric
CJ2
HVAC System, Air Conditioner Front, Automatic Temperature Control, Auxiliary Temperature Control
CJ3
HVAC System, Air Conditioner Front, Manual Temperature Control, Auxiliary Temperature Control
C25
Wiper System Rear Window, Intermittent
C36
Heater Auxiliary
C49
Defogger Rear Window, Electric
C5S
GVW Rating 6,600 lbs
C5W
GVW Rating 7,000 lbs
C5Y
GVW Rating 7,100 lbs
C6A
GVW Rating 7,300 lbs (3900 kg)
C69
HVAC System Rear, Air Conditioner
DF5
Mirror, Inside Rearview, Light Sensitive, Compass, Outside Temperature Display
DH6
Mirror, Inside Front Vanity, Left and Right, Sunshade, Illumination
DK8
Console Roof Interior, Deluxe
DL3
Mirror, Outside Left and Right, Remote Control, Electric, Heated, Power Folding, Turn Signal Indicator, Light Sensitive, Color
DL8
DPN
Mirror, Outside Left and Right, Wide Load, Vertical Glass, Manual Extending, Manual Folding, Heated, Turn Signal Indicator, Remote Control
DR4
Mirror, Outside Left and Right, Remote Control, Electric, Heated, Light Sensitive, Power Folding, Color
D07
Console, Front Compartment, Floor, Custom
EXP
Export
E52
Body Equipment One Piece Liftgate with Liftglass
E61
Door Rear Liftgate, Power
FE9
Certification Emission, Federal
FP7
Ratio Transaxle Final Drive 3.73
GT4
Axle Rear 3.73 Ratio
GT5
Axle Rear 4.10 Ratio
GU5
Axle Rear 3.23 Ratio
GU6
Axle Rear 3.42 Ratio
G63
Provisions Luggage Carrier, Roof
G69
Level Control Automatic, Air, HD
G80
Axle Positraction Limited Slip
JAN
Plant Code - Janesville, WI, USA
JD9
Brake Vac Power, 17 inch Disc/Disc, W/VSES, 7,700 lbs
JF4
Pedals Adjustable, Power
JK1
Indicator Low Tire Pressure - Delete
J81
Indicator Switch, Export
KA6
Heater Seat, Rear
KA9
Heater Steering Wheel
KB6
Heater Seat, Cooling, Front
KNP
Cooling System Transmission, HD
KW1
Generator 160 Amp
K05
Heater Engine Block
K34
Cruise Control, Automatic, Electronic
K47
Air Cleaner High Capacity
LMG
Engine Flexible Fuel (GAS/ALC), 8 Cylinder, 5.3L, SFI, V8, OHV, Cylinder Deactivation, Iron, GM
LY2
Engine Gas, 8 Cylinder, 4.8L, SFI, Iron, GM
LY5
Engine Gas, 8 Cylinder, 5.3L, SFI, Iron, Cylinder Deactivation, GM
L92
Engine Gas, 8 Cylinder, 6.2L, SFI, ALUM, Cylinder Deactivation, HO GM
MAU
Marketing Area Unregulated
MSL
Plant Code Silao, Mexico
MTF
Provisions Fire Extinguisher Mounting
MYC
Transmission Auto 6-Speed, HMD, 6L80
M30
Transmission Auto 4-Speed, HMD, 4L60-E, Electronic
NE1
Certification Emission, Geographically Restricted, Restriction For Vehicles Up To 14,000 lbs GVW (Use 2003 Model Year)
NF9
Emission System General, OBD MIL Suppression
NK5
Steering Wheel Standard
NP5
Steering Wheel, Leather Wrapped
NP7
Steering Column EEC Approved
NP8
Transfer Case Active, 2 Speed Push Button Control
NR3
Transfer Case All Wheel Drive (AWD), Open Differential, Single Speed
NT4
Emission System EEC 05
NT8
Emission System Federal, Tier 2 A
NU1
Emission System California, Level 2
NU4
Emission System California Level 2 Plus
NU5
Emission System California BIN 4
NX7
Wheel 17 x 7.5, Steel
NZZ
Sales Package, Skid Plate Off-Road Spot
NZ4
Wheel Spare Full Size, 17 inch Steel
N12
Exhaust System Rear Exit
N30
Steering Wheel Deluxe
N87
Wheel 18 x 8, Aluminum
N88
Wheel 17 x 7.5, Aluminum, Premium
N93
PD0
Wheel 20 x 8.5, Aluminum, Chromed
PD5
Wheel 18 x 8, Aluminum, Chromed
PPV
Vehicle Police, Package
PW2
Wheel 18 x 8, Aluminum, Machine Faced
PZZ
Plate Front Underbody, Skid
P41
Wheel 20 x 8.5, Aluminum, Polished
P46
Wheel 17 x 7.5, Aluminum, Uplevel
P56
Wheel 22 x 9.0, Aluminum, Chrome
QAN
Tire All P265/70R17-113S BW R/PE ST TL AL2
QAS
Tire All P265/70R17-113S WOL R/PE ST TL AL2
QBL
Tire All P265/70R17-113H BW TL ST OOR
QF7
Wheel 17 x 7.5, Aluminum, Deluxe
QF8
Wheel 18 x 8, Aluminum, Polished
QJM
Tire All P265/70R17-113S WOL R/PE ST TL OOR
QJP
Tire All P265/70R17-113S BW R/PE ST TL OOR
QSS
Tire All P275/55R20-111S BW TL ST AL2
QST
Tire All P285/45R 22 BW TL AL2
QVT
Tire All P265/60R17-108H BW TL AL3 Police
QV9
Wheel 17 x 7.5, Steel, Police
QXK
Tire All P265/65R18-109S BW TL AL2
QXN
Tire All P265/65R18-112S BW TL OOR
QXO
Tire All P265/65R18-109H BW TL AL2 Export
RCS
Wheel 20 x 8.5, Aluminum, Polished Finish (Chevrolet)
RDP
Wheel 20 x 8.5, Aluminum, Polished Finish (GMC)
RYJ
Shade Cargo Area, Retractable
SLT
Equipment LT Sales Package
TL1
Grille, Special
TQ5
Control Intelligent High Beam
TR2
Lamp Turn Signal, Enlarged
T62
Lamp System Daytime Running - Delete
T64
Battery - Delete
T74
Headlamps Control Automatic, Delay
T78
Headlamps Control - Delete
T79
Lamp, Fog, Rear
T84
Headlamps RH Rule of the Road, E Mark
T89
Lamp, Tail and Stop, Export
T96
Lamp Fog, Front
UC2
Speedometer Instrument, Kilo and Miles, Kilo Odometer, Positive Bias
UD4
Alarm Vehicle Speed, 120 km/h
UD7
Sensor Indicator Rear Parking Assist
UE0
Communication System Vehicle, G.P.S. - Not Installed
UE1
Communication System Vehicle, G.P.S. 1
UG1
Opener Garage Door, Universal
UG2
Opener Garage Door, Universal - Delete
UJ6
UK3
Control Steering Wheel, Accessory
UK6
Radio Control, Rear Seat and Earphone Jacks
UL2
Frequencies, European
UL8
Frequencies, Saudi Arabian
UN9
Radio Equipment, Suppression
UQA
Speaker System, Premium Audio Branded With Amplifier
UQS
Speaker System, Premium Audio Branded With Surround Amplifier
UQ3
Speaker System, Enhanced Audio
US3
Antenna, Diversity
US8
Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
US9
Radio AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UT7
Provisions Auxiliary Electrical System Ground
UVA
Radio AM/FM Stereo, Seek/Scan, Auto Tone, CD, CD-R, MP3, DVD, Clock, ETR, RDS
UVB
Radio AM/FM Stereo, Seek/Scan, Auto Tone, CD, CD-R, MP3, DVD, NAV, Clock, ETR, RDS
UVC
Camera, Rear View
U19
U2K
Digital Audio System S-Band
U3R
Radio AM/FM Stereo, WX, Seek/Scan, CD, DVD, NAV, Clock, DSP, RDS, W/Voice Rec Micro
U3U
Radio AM/FM Stereo, Seek/Scan, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3
U34
Display, Celsius Temperature
U42
Entertainment Package Rear Seat
U84
Antenna Body Side Window, Radio
VD1
Provision Options Europe
VFF
Video Format Region 1, NTSC
VFJ
Video Format Region 2, PAL
VFK
Video Format Region 3, NTSC
VFM
Video Format Region 4, NTSC
VFP
Video Format Region 5, PAL
VGC
Protector Film, Paint Etch Preventive
VGD
Fascia Front, Custom, Body Color
VGE
Fascia Rear, Custom, Body Color
VG8
Vehicle Label, Notice to Buyer
VJ3
Label, Plate ECE Approval and Vehicle Identification
VK3
License Plate Front, Front Mounting Package
VL4
License Plate Front, Front Mounting Package, EEC
VL5
License Plate Rear Mounting Package, Export
VPH
Vehicle Preparation Overseas Delivery
VR4
Trailer Hitch Weight Distributing Platform
VVJ
Calibration, Speedometer (180 km/h/ 112 mph)
VVK
Calibration, Speedometer (200 km/h/ 124 mph)
VXS
Vehicle Complete
VZ2
Calibration, Speedometer A
V08
Cooling System Heavy Duty
V1K
Bar Luggage Carrier, Center Cross
V54
Luggage Carrier, Roof, Painted
V73
Vehicle Statement, USA/Canada
V76
Hook, Tow
V78
Vehicle Statement - Delete
V87
Vehicle Statement Gulf States Organization
WX7
Wiring Provisions
XA7
Washer Nozzles, Heated, Windshield
X52
Miscellaneous Equipment for Guam, Puerto Rico/US Virgin Islands
X88
Market Brand Chevrolet
YE9
Convenience Package Comfort and Decor Level #3
YF5
Certification Emission, California
YQ3
Infotainment System - 011
Y91
Merchandised Package Luxury Edition
ZBL
Tire Spare P265/70R17/113H BW TL ST OOR
ZVL
Tire Spare P265/70R17-113S BW R/PE ST TL ALS
ZVT
Tire Spare P265/60R17-108H BW TL AL3 Police
ZW7
Chassis Package Premium Smooth Ride
Z49
Export Canadian Modification Mandatory Base Equipment
Z5X
Mirror Provisions Arabic Language
Z55
Chassis Package Bi-State Real Time Damping
Z56
Chassis Package Police Conversion
Z71
Chassis Package Off Road
Z75
Market Brand Cadillac
Z82
Trailer Provisions Special Equipment, HD
Z88
Market Brand GMC
5W4
Vehicle Special Service, Municipal
6B2
Handle Rear Door, Inoperative
6E2
Cylinder Unit Single Key System, Coded DF81
6E8
Cylinder Unit Single Key System, Coded NU97
6J1
Wiring Provisions Ignition and Main Power Supply
6J3
Wiring Provisions Headlamp Flasher, Grille Lamps and Speakers
6J4
Wiring Provisions Horn/Siren Circuit
6J7
Flasher Headlamp
6N5
Handle Inoperative, Rear Window
6N6
Lock Control Rear Door, Inoperative
7B7
Grille Radiator, Argent
7X6
Spotlamp Left, Pillar Mounted, Halogen
7X7
Spotlamp Left and Right, Pillar Mounted, Halogen
9G8
Equipment Daytime Running Lamp and Headlamps Control - Delete
lowlife
thats for my Sub.. I can look yours up to if you give me a year and model or I can go one step further and nail completely with your VIN.
