Blinker Fuse
PotentialTahoe
Looking for drivers side blinker fuse. Passeng. side blinkers work fine, but the drivers side blinkers do not work at all. Thanks
98hoe
Might not be the fuse. Sounds like the switch. I could be wrong but I think the fuse is for both blinkers. Hence the problem lying in the switch.
GMCYukalade
NC
Maybe you just need to fill up the blinker fluid? - nah, i do belive that the fuses are the same just 1 fuse - um, but you can always look in the owners manual and find out - also look for a broken wire
PotentialTahoe
Yes, adding fluid does usually help, but I agree with you, its not the fuse or else the other side wouldn't be working. Now I noticed that one of the front orange lamp blubs is busted, I wondered if that one break in the circuit would cause the whole side to go out, almost like the christmas light effect.
GMCYukalade
NC
if it is broken, and grounding the blinker, it may very well not let the back work either
