MikeCallery
- Feb 25, 2008
Fusible Link:
O.K. I'm learning so for those of you like me, here is a great web page that I found which tells you a bit about a fusible link:
http://www.carcare.org/Electrical/fusible_link.shtml
It sounds like something that I should put on my 2 guage wire from the battery to the alternator. I am not worried about the accident because the alternator is going to stop so that isn't much of a concern.
It looks like the best location would be to put a fusible link right where the wire goes to the battery at about 200 amps. That would allow the alternator to go to full capacity and the battery can easily handle that. Anything above and then you start getting into the alternator going bad and it's a safety situation. I doubt the wire would ever get too hot so that won't be an issue.
