Well I got the new plugs installed today, starts up a fraction smoother, other than that no noticeable difference, will have to check my econ and see if that helped at all. The old plugs were definitely dirty, and a couple of them had some corrosion and rust around the collar, glad I replaced them
Didn't see any sign of leaking coolant where the gaskets are, but even with the mirror it was hard to check, found a super-slow oil leak around the oil cooler but tightened the bolts and that should solve that hopefully
my reserve bottle doesn't seem to hold antifreeze, not sure if this is indicative of the LIM gasket problem or if its just a problem with the bottle itself or natural evaporation, I have really only added coolant to it once anyways
Was going to do the helper springs today but the kit was missing the Ubolts, called the company and getting ubolts sent out in a few days
Also ordered a pair of Laclede sport pro tire chains, will be making a couple pass trips this winter and better safe than sorry, plus $30 is a solid price
