Polecat
no kidding?? who??i co-own a car audio company based out of FL.
**** very much danger......on the cap there should be 2 terminals....+ and a - .....first thing is to undo the power supply the cap goins inline on the (+) side of the power supply and also hook the (-) to the ground inlined with the amp......do NOT EVER EVER EVER TOUCH OR ARC ACROSS THE CAPS TERMINALS....THIS CAN BURN UP THE CARS ELECTICAL SYSTEM AND OR KILL YOU BY STOPPING YOUR HEART.......SO HOOK THE CAP IN BEFORE YOU HOOK UP THE (+) POWER TO THE SYSTEM
I foud this searching online via Wikianswers. I'm a lil confused!
I thinking that I run Power Cap before Disto Block and then hook up ground from 1 amp to the Capand then from the same terminal run a ground to rear seat bracket?
i would not use a distro block when i use a cap... i run pos from batt to cap then from cap to amps(bass,mids/highs).. then ground the cap... i use sep grounds for the amps....
