Bad Sound When Backing Up...?
96CHEVYMAN
When i back up it sounds like there is a metal strewdriver clanking on a metal pole and i was wondering what that would be??
volcomguy53
nc
mine did a simalar thing right before the spider gears went out might want to have that check but if it is spider gears i think the replacements arent but like 20 something dollars
96CHEVYMAN
tranny probs solved
it turns out that when i took it to the shop by my house that it was the rear transmission u joint was broken most likely from going offroading but i dont care i still will do it but jus some light muddin.
thanks for responding,
mike
GMCYukalade
NC
I don't know how things are on your 96.. but my 99 and muddin.. turned out to be an expensive idea.. i've replaced 4 rear-ends, like 2 u-joints, and it needs a CV axel - every wiring harness underneath is packed with mud, and one night Muddy water got into the air intake tubing.. the truck backfired.. wouldn't crank for like 20 mins.. when it did it ran like crap.. - when it backfired on one side of the motor it completly closed the gap on the plugs, on the other, it opened them up fully
96CHEVYMAN
Bad shaking of engine.
I was driving down the highway and i heard a big boom, and the tahoe started to shake and i could only go 45 miles per hour. It smells like gas and oil mixing and burning and intake is not sucking right cuz it sounds like its trying to suck thru a straw.
