Alternators and Output Amps
treepete
Genesee Twp, WI
Guys, I have a 99 yukon denali. what is the output amperage of my alternator? is there a way I can measure it at idle?
Here are the RPO codes of the alternators available for your truck (I believe these are correct).
RPO - Rated Amps
K60 100 A
K68 105 A
Alternator model: CS130D
KW2 124 A
KG9 140 A
Alternator model: CS144
Black96
willamsport PA (college) souderton Pa ( home)
or if u want Snap-on makes an awsome D-Tac plus that u hook up to the batterys and it will messure it all for u, just put the amp prob on ur lines and it will tell u if ur starters bad, bad batterys, or if the diodes are bad
