Alternator replacement
REDYUKON
Minnesota
How hard is to replace alternator on 2001 Yukon? I have never done this before and Chilton manual is very confusing to me. Anyone has a write up on this?
c19dale
should be very simple. Not looking at it right now, but I believe it is right there on top. put a socket on the tension pulley (top left) and pull it till you have slack to remove the belt. Once the belt is off, unplug the alternator then unbolt it....should be 2 bolts, sometimes 3 on some cars. remove and replace....please don't pay the dealer to do this...it's one of the easiest components to replace. You can tackle it...
REDYUKON
Minnesota
Thank you
Thank you for the info. I will tackle this myself.
Very simple to do, familiarize yourself with your motor's basic components and you'll be able to fix most issues that may arise.
REDYUKON
Minnesota
Thanks
Yeah, It is just the matter of do I want to go with 105AMP or something higher? I have seen 145AMP ones and leaning towards the higher AMP ones.
