Hey whats up everybody great site I just bought a 2001 GMC Yukon lifted on 35's, I bought an alarm its a Clifford 2way with remote start built in, I installed the alarm got the door's, locks, lights, etc, tied in aux channel latched to turn on my 3 monitrors for the dvd system , all with no problem. I did have problems getting the remote start to work I am MECP certified installer even though I have moved on industrial controls for my professional career. ok I had trouble locating the tach input wire which is supposed to be white wire coming out of a red plug on the ECM located in the engine compartment. I didnt want to disconnect the battery or any of the wires on the ECM module, I got the yukon to turn on the ignition, even turn over it almost starts but doesnt quite make it, seems like it is missing an ignition I have followed DEI's wiring instuctions and the only wire that isnt connected from the ignition is the brown which is listed as a seond Accessory I saw another thread in this forum listing the brown as a third igniton wire? I bought the truck used and I think it only came with the factory keyless entry looked my SUV up and the DEI dealer did as well and no VATS kit is required. I hooked a relay up throwing a - pulse to the factory disarm wire, should i add an additional relay up to the second ignition ouput of the relay pack and power the brown off of this any info would be greatly appriciated and the yukon starts instantly with the key that came with it and the 2 copies I got made at Walmart for a 1.50 each.
