Air Suspension........Anybody?
aftermarket, or stock, i have the stock air suspension and all i know is that it levels the truck, and raises the back end when i tow the boat.
riceplanter
KY
Aftermarket, what im looking for is a quick, and simple air suspension setup. Mostly bolt on, if i have to, i need to learn how to weld! Any info will help me!
Depends on what you want, I would check out the lowered/street suspension forum on www.gmfullsize.com for some bag advice but I have seen a few people run autoride with airbags before (built shock mounts around suspension). Best way to do it would be deleting the torsion bars for a slamair bag or air strut of some nature along with a couple viair 480c's and a 10-15 gal tank. Torsion bar suspensions are not easy to bag so I would recommend staying static drop on these trucks, buy an obs scsb chevy if you wanna bag some sh*t out :yesnod:
riceplanter
KY
This website has helpful "how to" segments! Thanks!
Here you go, you can build a kit for fairly cheap or just drop your truck at a reputable shop for a 6 link with watts link and it will ride better than stock
showthread.php
