Air PSI Message, after putting on 20's??
M.M. 700
I put a set of 20's on today, everytime a start in it gives me a "Service Tire PSI" or something to that effect. Anyway to get rid of it????
2004 4x4 Tahoe came factory with 17's
I am sure there is a post about this, but couldn't find anything????
Gordo
Denver Area
It could be that your old wheels had the sensors and they werent put on your new wheels
JennaBear
CA
Did your tire shop reset your sensors? There is a procedure in the owner's manual for them.
The shop should have swapped the sensors for you, they're located in the valve stem as part of the assembly. Check your old wheels and tires for the sensors:
You may have to recalibrate the sensors, I've never done this on a gmt800 but the new bodies are the same way and should be similar
Resetting the TPMS Identification Codes
Each TPMS sensor has a unique identification
code. Any time you rotate your vehicle’s tires or
replace one or more of the TPMS sensors,
the identification codes will need to be matched to
the new tire/wheel position. The sensors are
matched to the tire/wheel positions in the following
order: driver’s side front tire, passengers side
front tire, passengers side rear tire, and driver’s
side rear tire using a TPMS diagnostic tool.
See your GM dealer for service.
The TPMS sensors may also be matched to each
tire/wheel position by increasing or decreasing
the tire’s air pressure. If increasing the tire’s
air pressure, do not exceed the maximum inflation
pressure indicated on the tire’s sidewall.
You will have two minutes to match the first
tire/wheel position, and five minutes overall to
match all four tire/wheel positions. If it takes longer
than two minutes, to match the first tire and
wheel, or more than five minutes to match all four
tire and wheel positions the matching process
stops and you will need to start over.
The TPMS sensor matching process is outlined
below:
1. Set the parking brake.
2. Turn the ignition switch to RUN with the
engine off.
3. Using the DIC, press the vehicle information
button until the RELEARN TIRE POSITIONS
message displays. If your vehicle does not
have the DIC buttons, press the trip odometer
reset stem located on the instrument panel
cluster until the RELEARN TIRE POSITIONS
message displays.
4. If your vehicle has the DIC buttons, press the
set/reset button. The horn will sound twice to
indicate the TPMS receiver is ready, and
the TIRE LEARNING ACTIVE message will
display. If your vehicle does not have the DIC
buttons, press and hold the trip odometer
reset stem until the horn chirps twice and the
TIRE LEARNING ACTIVE message is
displayed.
5. Start with the driver’s side front tire.
6. Remove the valve cap from the valve cap
stem. Activate the TPMS sensor by
increasing or decreasing the tire’s air pressure
for five seconds, or until a horn chirp
sounds. The horn chirp, which make take up
to 30 seconds to sound, confirms that the
sensor identification code has been matched
to this tire and wheel position. To decrease
air-pressure out of a tire you can use the
pointed end of the valve cap, a pencil-style air
pressure gage, or a key.
7. Proceed to the passenger’s side front tire, and
repeat the procedure in Step 6.
8. Proceed to the passenger’s side rear tire, and
9. Proceed to the driver’s side rear tire, and
10. After hearing the confirming horn chirp for the
driver’s side rear tire, the horn chirp will sound
two more times to signal the tire learning
mode is no longer active. Turn the ignition
switch to LOCK.
11. Set all four tires to the recommended air
pressure level as indicated on the Tire
and Loading Information label.
12. Put the valve caps back on the valve stems
Oh and :ttiwwop:
M.M. 700
well da&^ it. I had them mount the tires on the rims and I put the new wheel/tires on. The sensors are not on the new wheels......Oh well
CHISTOSO
Tempe, Arizona
Boost, Awesome post man!!!
I read somewhere that you can just drill out 3 extra holes on your spare and have the sensors mounted and programmed on it therefore not needing to swap onto custom rims or reprogrammed... Some wheels do not accept TPMS's. Don't know if it would actually work since each sensor has to be programmed individually..
I personally dont have them on mine, it's a pain in the arse having to press the info button on the steering wheel to cancel message on the dash but my wheels don't accomodate TPMS's.. I'm looking for good options..
Just take them back and have them install the sensors, I'd make them rebalance the wheels too. Where the pics at?!!
M.M. 700
I will get some pics. 2 of the wheels have to be replaced. 1 has spots by the lug nuts where it looks like the chrome did not stick to....it looks like the cancer rust on a paint job. The other has a brown spots on it, looks like something happend in the chroming of the wheel.
Other than that, it looks GREAT. Rides the same if not better, which I did not expect.
M.M. 700
anyway to get rid of the message without putting the sensors in the new rims?????
nutt121
fellas i got a 2000 yukon xl and i want to put a doubledin touch screen nav/dvd unit in it but some cutting is going to be invlved has anyone done this ,and do you have pics/ any suggestions
thanks guys
nutt121/I]
