Hey gambler (or anyone else),
Do you have pictures of the front and rear door internals? Mounts, wiring etc... Any tips for pulling the panels off? did use the factory wiring or upgrade with higher quality speaker wire throughout the doors?
Also, would it be possible to fabricate a mount for a tweeter in the c pillar somewhere at upper body height? is that even a good place to mount a tweeter for acoustics?
Thanks again!
I didn't take pics of the inside. I need to take the door off to adjust the crossover again anyway :cuss: I'll try to take some when I do that.
I used the images in
this thread to learn how to get the doors off. They are pretty easy after you do the first one. I think a summary is:
-Pop the triangle piece off (where I put my tweeters)
-Pull the tab on the lock and lift it straight up
-Pop the panel behind the door handle, remove both bolts
-Pop the panel behind the armrest, remove both bolts
-Use a trim tool to pop all of the pins off (the door should be loosened now)
-Pop the controls trim off, disconnect and remove
-Unscrew the door handle from the back (2 screws), pop off and slide back through the door
-Done!
For the speaker brackets I made some out of half inch MDF. There is plenty of room back there to use any size you want. I put some sound damping down on the bare metal between the MDF brackets and the door.
I upgraded the wiring. It is a little tricky getting the wires through the flexible rubber tube on the door. I had to pop off both ends of the tube (use a flat screwdriver to push the clip in and they pop right off), then fish the wire through and reattach.
I would NOT recommend placing a speaker on the C pillar. You want your soundstage in front of you and if you want rear-fill only put a pair of coaxials in the rear doors as they are low enough. I ditched the rears all-together, but that is up to you.
