Accerlation problem 99
jakeatkins
I have a 99 Tahoe 4x4 5.7 180K
This has been a great vehicle up until the last few months, problems are starting to creep up. Expected for 180K and up until now I have been able to diagnose and fix everything that has come up.
Whe I try to accelerate from a stop or a rolling stop the truck will flat out not accelerate for about a block then it opens up. I can push it too the floor and the rpm climbs very slowly then she takes off. It usually happens when I have just started her and pull out of my drive way but also after driving for 50miles or so when I go to pass on the highway she wont accelerate.
I am thinking maybe a back pressure problem or fuel problem. Plugs, wires, cap and rotor are all new. Fresh oil. Fuel pump was replaced about 6K ago.
The only code is a downstream O2 sensor that has been on since before the problem started.
Any ideas the problem is?
Gas mileage? How long does fuel pressure hold? check tps.
Kinda sounds almost opposite of a cat issue.....
I suspect it may be flooding out on him.....
Have access to an OBD2 scantool? -watch your fuel trims when it is flaking out....
I wouldnt replace an expensive O2 without a reason, use the scantool to diagnose the issue...
samotahoe
San Diego, Cali
use a dvom to diag. thats the mistake that most techs do now days is using the scan tool as a diagnosis. you need to remember its a "tool" but in any case i said that cause if he didnt know how to test it just replace it. $50 02 is alot cheaper and easier than a $600 cat plus labor for muffler shop
A scantool can tell you alot about the sensor, most scantools will present you with o2 voltage, so why bother with a DVOM? If you want to test for a plugged cat, pull the o2 out and check for backpressure to the engine.
