Acceleration Issue?
ayeplussjr
I noticed today that my Tahoe has a pretty good kick to it when the truck shifts gears when accelerating from stop. When the truck changes gears I can notice a bigger kick than what I'm used to. Any ideas what can cause this?
MadMedwyn
How many miles to you have on it? I think you're supposed to have the fluid changed at 100k and but 50k if you tow alot.
ayeplussjr
I have about 38000 miles on it but it's shifting properly now....For some reason that day it just seemed like it was shifting a bit hard, but feels okay now, for the moment.
Gordo
Denver Area
hey you know what you can try and i recommend it is the lucas additive to your tranny fluid it improves your shifting and keeps your tranny cooler. I put it in my truck and after a few minutes noticed smoother shifting and cooler temp on the tranny
ayeplussjr
alright....i think something is definitely going on because when I was driving through my neighborhood on the way back home from work I felt a big kick/jerk coming from the rear....I was only going about 10mph through the neighborhood, but when it started to shift it gave a big kick/jerk. It can't be my tranny fluid because that was just topped off about a couple of weeks ago. Anything else I can look at?
oomindwarpoo
CA
Mine does it too sometimes, only when its cold tho or you're too low of rpm in the gear and it will downhshift hard into whatever gear. I hate automatics...
thaslick1
Nashville
I think I have the same problem, when I start to accelerate I get a slight kick and then when it shifts to the second gear I get a clunk noise most of the times, I always wondered if that was a sign of tranny problems, I hope not bc I just bought this thing like 2 months ago
ayeplussjr
This was happening off and on with me for about a month and then the check engine light came on. The dealer said the solenoid valve was cracked so they replaced it under warranty and I haven't had any problems since.
