panther5
- Feb 9, 2008
i have a 95 2dr. the AC's not working and i think it's the compressor. Anyone ever replace one?
1995 - the gas or refridgerant could either be R-12 "Freon" and expensive and illegal for the consumer to replace in most states, or R-134a available in most automotive stores. Your engine compartment should say which it uses, check the top of the accumulator. The two gases aren't compatible so don't interchange. There are crossover kits, but it requires the evacuation, cleaning of your current system as different oils are used, and a vacumn to be set.
Good luck.
