AC problem
97TankHoe
Eustis, FL
The AC in my 1997 Tahoe will stop working occasionally, But will start working again after I take the fuse out of the cabin and put it back in. The fuse is not blown and it works perfectly after I reinsert the fuse. Have no idea what's causing this
When it isnt working, check for 12v at compressor coil... if no voltage, suspect bad control head IMHO..... High/ Low Pressure Switch, and or AC Compressor Relay.....
