AC/Heat Blower stopped working
98-New 2door
I'm getting 0% blowing. Got in and it worked, turned if off then later on the same trip I went to turn AC on again and got zero air flow - nothing. ANy ideas on what it could be? I am not technical savvy at all
Fan motor, switch, relay, fuse, resistor pack, wiring......
Do you have any of the speeds? If no, then you can probably eliminate either the resistor pack or relay IIRC.....
AZYUKON
Did you ever figure out what your issue was?? I'm having a similar issue in where my AC used to only work on the high setting but now, it won't turn on IN ANY speed setting. My father in law did something where he ran a wire from the battery down by the footing in the passenger seat and it blew cold while he made a connection so he says it has to do with my ac/heater control. But then I read on forums that it could just be the speed switch. Also, my rear ac works just fine.
Could be the switch, if it has been ran too long, you probably burnt up the connector to the harness as well, and they do sell that as a replacement item as well......
